gordoncappo's avatar
gordoncappo
2 years ago
Can't work with aggregates because Power BI not recognizing column as numeric data
Ive dug through all the documentation and forum posts but can't seem to find a solution. Power BI will not recognize a column in my data as numeric which is preventing me from leveraging the aggregation features.
Link to what I am talking about:  https://learn.microsoft.com/en-us/power-bi/create-reports/service-aggregates
I have done the following so far:
  • Changed data type to type number in Power Query
  • Data type on PBI desktop set to Whole Number
  • Format on PBI desktop set to Whole Number
  • Summarization set to Sum
  • Running the February 2024 version of PBI Desktop.
I am not seeing the Numeric Field Sigma icon anywhere too.  It doesnt show up next to the column on Report View, Table View, or Model View. When I drag my "Value" column to a "Values" field in a visual, it does nothing. Below is a screenshot of what I see. Why is the Sigma symbol missing? Is this a setting issue?
  • Hello gordoncappo ,
    then there's a value im your field that is not a number that is preventing you from converting the column to an aggregate.
    • gordoncappo's avatar
      gordoncappo
      Hi Idrissshatila thank you for your response.
      I don't know how that would be possible because there is no data error in power query and I can write a simple SUM formula on the column with no issue. Screenshot of the the column quality in power query.
      • Idrissshatila's avatar
        Idrissshatila
        gordoncappo ,
        if you can write a sum measure then what's the problem, you could write a measure to aggregate.
