JBBaxter's avatar
JBBaxter
7 years ago
Call Google Search Console API with Power Query (M) - Web.Contents( POST Problem)
Hi Guys,
i managed to work with googles oath2 in including a refresh of the access_token in Power Query (M), (what a pain to get the first token and the refresh token) made also my first requests via GET.
::is working
    AccessTokenList = List.Buffer(api_token),
    access_token = AccessTokenList{0},
    AccessTokenHeader = "bearer " & access_token,
    GetJsonQuery = Json.Document(Web.Contents("https://www.googleapis.com/webmasters/v3/sites?&access_token=" & access_token))
    GetJsonQuery
so now i tried to call the /searchAnalytics/ query wich works with post :
    JsonRecords = Text.FromBinary(Json.FromValue(Source)),
    JsonRequest = "{
  ""startDate"": ""2019-01-01"",
  ""endDate"": ""2019-02-01"",
    JsonContent = Text.ToBinary(JsonRequest),
    AuthKey = "Bearer " & access_token,
    Response = Web.Contents("https://www.googleapis.com/webmasters/v3/sites/https%3A%2F%2Fwww.xxxxxxx.xxx/searchAnalytics/query", [Headers=[Authorization=AuthKey, ContentType="application/json", Accept="application/json"], Content=JsonContent]),
    JsonResponse = Json.Document(Response)
    JsonResponse
getting a bad request (400) - [auth header is working fine] already tested it, so there must be something wrong with the Header request aka Content=(body) or formating. Request body needs to have "startDate": "YYYY-MM-DD" and "endDate": "YYYY-MM-DD",
Google reference:
https://developers.google.com/webmaster-tools/search-console-api-original/v3/searchanalytics/query
Any Idea?
  • v-yuta-msft's avatar
    v-yuta-msft
    JBBaxter ,
    This issue should be caused by invalid format of the query in body. How about use format like YYYY/MM/DD?
    Community Support Team _ Jimmy Tao
    • JBBaxter's avatar
      JBBaxter
      Thanks for your reply, v-yuta-msft
      I tested it:
          body = "{ ""startDate"": ""2019/01/01"", ""endDate"": ""2019/02/01"" }",
          url = "https://www.googleapis.com/webmasters/v3/sites/https%3A%2F%2Fwww.xxxxxxx.xxx/searchAnalytics/query",
          Response = Web.Contents(url, [Headers=[Authorization=AuthKey, ContentType="application/json", Accept="application/json"], Content=Text.ToBinary(body)]),
          JsonResponse
      Still gives me a 400
      any other ideas? maybe (WebMethod.Post or WebAction.Request)?
      Thx
    JBBaxter , Did you solve this problem? I have a question, when you've created the API Application in google API console, did you use OAuth authentication (with client ID) or API Token? Thans
