6 years agoNot applicable
Calculating difference between two values per category
I have this issue. One (groupBy table): week costs orderID 1 10 001 1 12 002 2 15 001 2 18 002 One order table: ...
- 6 years ago
Hi Anonymous ,
You can create your measure like so:
Costs Measure = VAR Order_ID = MAX ( 'order table'[orderID] ) RETURN IF ( HASONEVALUE ( 'order table'[supplier] ), MAX ( 'groupBy table'[costs] ), MAX ( 'groupBy table'[costs] ) - CALCULATE ( MAX ( 'groupBy table'[costs] ), 'order table'[orderID] = Order_ID - 1 ) )And if you have more than 2 suppliers, you can ceate measures like so:
Diff = VAR Order_ID = MAX ( 'groupBy table'[orderID] ) - 1 VAR Previous_Costs = CALCULATE ( MAX ( 'groupBy table'[costs] ), FILTER ( ALLEXCEPT ( 'groupBy table', 'groupBy table'[week] ), 'groupBy table'[orderID] = Order_ID ) ) RETURN MAX ( 'groupBy table'[costs] ) - Previous_CostsPBIX file attached.
IceyIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Ashish_Mathur
6 years agoHi,
How will you calculate the difference row if there are more than 2 suppliers?
