GilesWalker's avatar
GilesWalker
Skilled Sharer
10 years ago
Calculating difference between two times
Hi Everyone,
I am having a lot of trouble trying to get a tidy result for calculating the difference between two times. One column has actual arrival, and the other has scheduled arrival. Is there a way to get an answer to look like this for example 01:14:43?
Heres an example of the data:
Hope someone can help.
Giles
  • Yes there are ways. The solution will depend on your data type, and you will presumably also need to manage the scenario when the day changes. If it were me, I would first make sure the data in the columns is in the format date/time. You can then just do a simple [actual] - [planned] to get the difference. If you format this as a time only, it should format the time as you want. The only issue will be of the arrival time is > 24 hours late.
  • MattAllington's avatar
    MattAllington
    • GilesWalker's avatar
      GilesWalker
      Skilled Sharer
      MattAllington - Thanks Matt, the data is in a time format however I did not have the answer [difference] in time format.
      Giles
