Calculating difference between rows (Duration).
- Anonymous7 years ago
Can handle something like this ( as with pretty much everything) in Power Query or DAX. I prefer to use Power Query for as much as I can, so that's the route I went. Please see the attached PBIX file below and you can step through the applied steps, but here's a quick overview:
- Sort the data ascending by Date and then by time
- Group the data by date, as I assume there will be more than 1 day of data
- Add an Index column to each sub-table, one starting at 1 and one starting at 0
- Merge the sub-table with itself using those two index columns
- This will pull in the previous row's time (and since we sorted earlier, it is in the correct order)
- Expand the merged table to show Time.1
- Sort the sub-table again, by Time and ascending
- Add a custom colum to each sub-table that subtracts Time and Time.1, this is your duration
- Select only the columns you want ( in the example I kept Date, Time, Duration)
- Expand the entire column and all your data will be there with the appropriate Duration measure
- Set your data types and you are good to go
Here's the code if you are so inclined, I'd rather step through but that's just me
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bVJJjgJBDPtLn5HIWou/gvj/N3CB0DBKpD7ZFTux+/G4/K77bqL7ul0CGZB1PW//cYNt5Ci4QxWSDZ4TPgseUOJVP2AOkwb3zZGCJ8W79wMqiCi4GnRQqyPo3FymDtnwRmqcjLx6kzB+VokFpVTjsZCri5vPjYvVXEmkd8GaIJMlVcLf1X0nTH4qIm4Fz5NU7ILz5rNuwSc0EFLwBZuI6suCZMG1EgrNv2B/CIOwbe8I/mZWd2V5rryvJTjUSMUpT+p5p1Xt8vvU3XnMU543UutEqI35ZlDd5XT2Y1MJRsK661an7vWWer4A", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type date}, {"Column2", type time}}), #"Renamed Columns" = Table.RenameColumns(#"Changed Type",{{"Column1", "Date"}, {"Column2", "Time"}}), #"Sorted Rows" = Table.Sort(#"Renamed Columns",{{"Date", Order.Ascending}, {"Time", Order.Ascending}}), #"Grouped Rows" = Table.Group(#"Sorted Rows", {"Date"}, {{"Data", each _, type table}}), #"Removed Columns" = Table.RemoveColumns(#"Grouped Rows",{"Date"}), #"Added Custom" = Table.AddColumn(#"Removed Columns", "Index1", each Table.AddIndexColumn( [Data], "Index", 1,1)), #"Removed Columns1" = Table.RemoveColumns(#"Added Custom",{"Data"}), #"Added Custom1" = Table.AddColumn(#"Removed Columns1", "Index2", each Table.AddIndexColumn( [Index1], "Index2", 0, 1)), #"Removed Columns2" = Table.RemoveColumns(#"Added Custom1",{"Index1"}), #"Added Custom2" = Table.AddColumn(#"Removed Columns2", "Merge", each Table.NestedJoin( [Index2], {"Index2"}, [Index2], {"Index"}, "Merged", JoinKind.LeftOuter )), #"Removed Columns3" = Table.RemoveColumns(#"Added Custom2",{"Index2"}), #"Added Custom3" = Table.AddColumn(#"Removed Columns3", "Custom", each Table.ExpandTableColumn([Merge], "Merged", {"Time"}, {"Time.1"})), #"Removed Columns4" = Table.RemoveColumns(#"Added Custom3",{"Merge"}), #"Added Custom4" = Table.AddColumn(#"Removed Columns4", "Custom.1", each Table.Sort([Custom],{{"Time", Order.Ascending}})), #"Removed Columns5" = Table.RemoveColumns(#"Added Custom4",{"Custom"}), #"Added Custom5" = Table.AddColumn(#"Removed Columns5", "Custom", each Table.AddColumn( [Custom.1], "Duration", each [Time] - [Time.1] )), #"Removed Columns6" = Table.RemoveColumns(#"Added Custom5",{"Custom.1"}), #"Added Custom6" = Table.AddColumn(#"Removed Columns6", "Custom.1", each Table.SelectColumns([Custom],{"Date", "Time", "Duration"})), #"Removed Columns7" = Table.RemoveColumns(#"Added Custom6",{"Custom"}), #"Expanded Custom.1" = Table.ExpandTableColumn(#"Removed Columns7", "Custom.1", {"Date", "Time", "Duration"}, {"Date", "Time", "Duration"}), #"Changed Type1" = Table.TransformColumnTypes(#"Expanded Custom.1",{{"Date", type date}, {"Time", type time}, {"Duration", type duration}}) in #"Changed Type1"Final Table:
PBIX File
https://1drv.ms/u/s!Amqd8ArUSwDS0AvvfmqTtcjGCqmj
Hope it helps!
-Nick
- 7 years ago
hi, Anonymous
I suggest you use DAX to add a column
Step1:
Add an Index column based on Created Date clolumn
You could do this in Edit Queries or use Rankx Function
Step2:
Create a column by this formula
SpoilerDuration = DATEDIFF('Table'[Created Date],CALCULATE(MAX('Table'[Created Date]),FILTER('Table','Table'[Index]=EARLIER('Table'[Index])+1)),SECOND)Result:
here is pbix file, please try it.
Lin
"Merged",
JoinKind.LeftOuter
[Custom.1],
"Duration",
each
[Time] - [Time.1]
PBIX File
Hope it helps!
-Nick
Sorry for the late reply and thank you for the detailed response. I went through your steps and then and understood excaclty what it was your were doing with the data. This is a good solution that i will use in the future.
