8 years agoNot applicable
Calculating difference between consecutive rows
hello i am new to power bi , and i have some struggle with this. my data look like this (small portion:) DATE / sum 2018-07-01 / 200 2017-09-03 / 400 2016-19-04 / 500 i want to calcu...
- Anonymous8 years ago
Hi all,
i manged to solve this using this answer:
basicly i had to calculate for each date the previous date (under the current filters) and then return the result for that date
LivioLanzo
Solution Sage
8 years agoYou cannot do this by using a Calculated Column but you can do it using a Measure. Is a measure ok? Also can you include in the dataset you have provided any column that is relevant for the calculation
