Calculating difference between consecutive rows
- 9 years ago
Probably a pivot-operations is what you're looking for:
Check column "ProblemFieldID" -> Transform -> Pivot Column -> Choose "NumVal" in Value-Field.
This will return a table with 1 additional column per ProblemFieldID which you then can build your calculations on.
In the table, in column Problem ID every problem has 2 problemFieldID / one that show problem filed id 4 and one with problem field 7/
What I'm trying to calculate is
Problem id 6A6C4C2A-7328-4A91-B598-6F629C905A86 temprature = NumVal/Problem Field Id=4/ - (Problem id 4 - problem ID 7).
ProblemID | ProblemFieldID | NumVal | Result | Temperature |
6A6C4C2A-7328-4A91-B598-6F629C905A86 | 4 | 98 | text =(Problem id 4 - problem ID 7) | 10 |
6A6C4C2A-7328-4A91-B598-6F629C905A86 | 7 | 88 |
C8E745BC-7CC2-4220-97DC-503664FF5828 | 4 | 230 | text =(Problem id 4 - problem ID 7) | 43 |
C8E745BC-7CC2-4220-97DC-503664FF5828 | 7 | 187 |
D814D0FF-3B18-4C51-990D-F6FF4CAE15F1 | 4 | 93 | text =(Problem id 4 - problem ID 7) | 10 |
D814D0FF-3B18-4C51-990D-F6FF4CAE15F1 | 7 | 83 |
I was thinking that if the table is transpose:
Problem
ProblemID Comp T/ ProblemfieldID 4 Ref T/ ProblemfieldID 7
6A6C4C2A-7328-4A91-B598-6F629C905A86 98 88
I could say formula = Comp T - Ref t.
But I do not know how to transpose or rotate the table that way.
