Calculating difference between consecutive rows
- 9 years ago
Probably a pivot-operations is what you're looking for:
Check column "ProblemFieldID" -> Transform -> Pivot Column -> Choose "NumVal" in Value-Field.
This will return a table with 1 additional column per ProblemFieldID which you then can build your calculations on.
Greg_Deckler The rows could be not in the same order / might be 10 previous or 6 previous/.
OK, so then is the pattern that you always want to match problem ID's 4 and 7 or how do you know which earlier row to use?
- Lilia9 years ago
In the table, in column Problem ID every problem has 2 problemFieldID / one that show problem filed id 4 and one with problem field 7/
What I'm trying to calculate is
Problem id 6A6C4C2A-7328-4A91-B598-6F629C905A86 temprature = NumVal/Problem Field Id=4/ - (Problem id 4 - problem ID 7).
ProblemID
ProblemFieldID
NumVal
Result
Temperature
4
98
text =(Problem id 4 - problem ID 7)
10
7
88
C8E745BC-7CC2-4220-97DC-503664FF5828
4
230
43
7
187
D814D0FF-3B18-4C51-990D-F6FF4CAE15F1
4
93
10
7
83
I was thinking that if the table is transpose:
Problem
ProblemID Comp T/ ProblemfieldID 4 Ref T/ ProblemfieldID 7
6A6C4C2A-7328-4A91-B598-6F629C905A86 98 88
I could say formula = Comp T - Ref t.
But I do not know how to transpose or rotate the table that way.
- ImkeF9 years ago
- Anonymous9 years agoNot applicable
In addition to other’s post, you can directly create a column with the following formula in your current table.
Tem = var previous= CALCULATE(MAX(Table1[NumVal]),FILTER(Table1,Table1[ProblemID]=EARLIER(Table1[ProblemID])&& 'Table1'[ProblemFieldID]>EARLIER('Table1'[ProblemFieldID]))) return IF(ISBLANK(previous),BLANK(), 'Table1'[NumVal]-previous) )))))))
