mikesdunbar
2 years agoCalculate difference using minimum values
I'm trying to establish a value for whether someone underused or overused hours allocated to a project. For instance, Tom Smith wasn't forcasted to work on 3/4/2024, so he was over $80.40. On 3/19 Ni...
- Anonymous2 years ago
Hi mikesdunbar ,
In Power BI Desktop, you can create calculated column to achieve thisActual Rate = CALCULATE( MIN('Table'[Rate]), ALLEXCEPT( 'Table', 'Table'[User] ) )Billing Delt Rate = ('Table'[Forceasted hours] - 'Table'[Actual hours]) * 'Table'[Actual Rate]Fina output
Best regards,
Albert HeIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly
2 years agoNot applicable
Hi mikesdunbar ,
Actual Rate =
CALCULATE(
MIN('Table'[Rate]),
ALLEXCEPT(
'Table',
'Table'[User]
Fina output
Best regards,
Albert He
