mikesdunbar's avatar
mikesdunbar
2 years ago
Calculate difference using minimum values
I'm trying to establish a value for whether someone underused or overused hours allocated to a project. For instance, Tom Smith wasn't forcasted to work on 3/4/2024, so he was over $80.40. On 3/19 Ni...
    2 years ago
    Hi mikesdunbar ,
    In Power BI Desktop, you can create calculated column to achieve this
    Actual Rate =
    CALCULATE(
        MIN('Table'[Rate]),
        ALLEXCEPT(
            'Table',
            'Table'[User]
    Billing Delt Rate = ('Table'[Forceasted hours] - 'Table'[Actual hours]) * 'Table'[Actual Rate]
    Fina output
    Best regards,
    Albert He
    If this post helps, then please consider Accept it as the solution to help the other members find it more quickly
