Calculate difference between values in same column
I need to calculate the difference in mileages and quantity, to calculate the fuel consumption per vehicle and date. Can someone please help me?
- Anonymous2 years ago
I found the solution!
thought I'd share it with you, sice you've all been so helpfull.
Gereden km's tussen tankbeurten =
VAR CurrentVehicle = 'F: Tankgegevens'[Voertuignummer]
VAR CurrentDate = 'F: Tankgegevens'[Datum]
VAR CurrentKM = 'F: Tankgegevens'[KM-stand]VAR PreviousKM =
CALCULATE(
MAX('F: Tankgegevens'[KM-stand]),
FILTER(
'F: Tankgegevens',
'F: Tankgegevens'[Voertuignummer] = CurrentVehicle &&
'F: Tankgegevens'[Datum] < CurrentDate
)RETURN
IF(
NOT ISBLANK(PreviousKM),
CurrentKM - PreviousKM,
BLANK()
- BIswajit_DasImpactful Individual
Hello Anonymous can you provide an example of your expected result.
- AnonymousNot applicable
vehicle date quantity mileage diff in mileage consumption 8374 28/09/2023 46,6 99212 8374 2/10/2023 29,06 99605 393 13,52374398 8374 5/10/2023 30,09 99970 365 12,13027584 first, I need the difference in mileage (per vehicle number!/date), so i can make a measure for the consumption (difference in mileage/quantity).
Is that enough info?
- miTutorialsSuper User
Please try the below measure, change the table name accordingly.
Difference in Mileage = VAR Off_ = CALCULATE(SUM('Table (2)'[mileage]),OFFSET(-1,ALLSELECTED('Table (2)'[date ]),ORDERBY('Table (2)'[date ]))) VAR Cur_ = CALCULATE(SUM('Table (2)'[mileage]),OFFSET(0,ALLSELECTED('Table (2)'[date ]),ORDERBY('Table (2)'[date ]))) Return IF(ISBLANK(Off_),BLANK(), Cur_ - Off_)A detailed video on this functions are on my channel, do check it out.
New Dax Functions in PowerBI | Index, Offset & Window | MiTutorials (youtube.com)
Regards
Ismail
Hi Anonymous ,
Please follow these steps:
1. For the first column of your expected result, you can create the metric and write the following expression.diff = VAR _date = SELECTEDVALUE('Table'[date ]) VAR _maxdate = CALCULATE(LASTNONBLANK('Table'[date ],CALCULATE(SUM('Table'[mileage]))),FILTER(ALLSELECTED('Table'),'Table'[vehicle] = MAX('Table'[vehicle]) && 'Table'[date ] < _date)) VAR _per = IF(NOT(ISBLANK(SUM('Table'[mileage]))), CALCULATE(SUM('Table'[mileage]),FILTER(ALLSELECTED('Table'),'Table'[date ] = _maxdate)), BLANK()) RETURN IF(_per = BLANK(),BLANK(),MAX('Table'[mileage]) - _per)2.The result obtained is shown below.
For the second column of your expected result, I'm not really sure how I got it, I tried to calculate it in several ways, but all of them are different from your expected result, could you please describe again in detail how to get this result.
If your Current Period does not refer to this, please clarify in a follow-up reply.
Clara Gong
At VAR _per i receive the following error:The syntax for 'VAR' is incorrect. (DAX(VAR _date = SELECTEDVALUE('F: Tankgegevens'[Datum])VAR _maxdate = CALCULATE(LASTNONBLANK('F: Tankgegevens'[Datum],CALCULATE(SUM('F: Tankgegevens'[KM-stand]))),FILTER(ALLSELECTED('F: Tankgegevens'),'F: Tankgegevens'[Voertuignummer] = MAX('F: Tankgegevens'[Voertuignummer] && 'F: Tankgegevens'[Datum] < _date))VAR _per = IF(NOT(ISBLANK(SUM('F: Tankgegevens'[KM-stand]))),CALCULATE(SUM('F: Tankgegevens'[KM-stand]),FILTER(ALLSELECTED('F: Tankgegevens'),'F: Tankgegevens'[Datum] = _maxdate)),BLANK())RETURNIF(_per = BLANK(),BLANK(),MAX('F: Tankgegevens'[KM-stand]) - _per))).
- Ashish_MathurSuper User
Share the download link of the PBI file.
CALCULATE(
FILTER(
'F: Tankgegevens',
)RETURN
IF(
BLANK()
