Calculate difference between values for same id
I'm trying to calculate the difference in days, for the same id, between two values in column Responsable, but only when the Responsable has a new value - the difference between changes of the resposable. A sample input is bellow, Input columns Issue_ID, Date, Responsable:
| Issue_Id | Date | Responsable | Desired OutPut Change | Desired output LastChanged Date | Desired Output Days between Changes |
| 1202 | 1/8/2021 | Name1 | SameName | ||
| 1202 | 2/8/2021 | Name1 | SameName | ||
| 1202 | 3/8/2021 | Name1 | SameName | ||
| 1202 | 4/8/2021 | Name1 | SameName | ||
| 1202 | 8/8/2021 | Name1 | SameName | ||
| 1202 | 9/8/2021 | Name2 | ChangedName | 1/8/2021 | 8 |
| 1202 | 10/8/2021 | Name2 | SameName | ||
| 1202 | 11/8/2021 | Name2 | SameName | ||
| 1202 | 12/8/2021 | Name3 | ChangedName | 9/8/2021 | 3 |
| 1202 | 13/8/2021 | Name3 | SameName | ||
| 1202 | 14/8/2021 | Name3 | SameName | ||
| 1202 | 15/8/2021 | Name3 | SameName | ||
| 1202 | 16/8/2021 | Name3 | SameName | ||
| 1202 | 17/8/2021 | Name3 | SameName | ||
| 1202 | 18/8/2021 | Name3 | SameName | ||
| 1202 | 19/8/2021 | Name3 | SameName |
I've managed to calculate when the change is done:
Desired OutPut Change=
var _PreviousDate=maxx(FILTER(ALLEXCEPT(table,table[Issue_ID]),EARLIER(table[Date])>table[Date]),table[Date])
var _PreviousStatut= CALCULATE(max(table[Responsable]),FILTER(ALLEXCEPT(table,table[Issue_ID]),table[Date]=_PreviousDate))
var _Current= table[Responsable]
Return
if(_Current=_PreviousStatut,"Same","Changed")
But Im struggeling with calculating to return the previous date when the change happend and the difference.
Thanks!
Hey salexa ,
I tried a little bit different approach.
Check the following calculated column, this should give you the correct date:
Desired output LastChanged = -- save the date of current row in a variable VAR vRowDate = myTable[Date] -- calculate first date for current Issue_ID VAR vFirstDate = CALCULATE( MIN( myTable[Date] ), ALLEXCEPT( myTable, myTable[Issue_Id] ) ) -- calculate the date of the last change before this row VAR vLastChangeDate = CALCULATE( MAX( myTable[Date] ), ALLEXCEPT( myTable, myTable[Issue_Id] ), myTable[Desired OutPut Change] = "ChangedName", myTable[Date] < vRowDate ) RETURN -- return the values for the different cases SWITCH( TRUE(), myTable[Desired OutPut Change] <> "ChangedName", BLANK(), vLastChangeDate = BLANK(), vFirstDate, vLastChangeDate )And then the amount of days is an easy one:
Desired output LastChanged Days = DATEDIFF(myTable[Desired output LastChanged], myTable[Date], DAY)I did some comments in the measure in order to understand better what the measure is doing.
If you need any help please let me know.If I answered your question I would be happy if you could mark my post as a solution ✔️ and give it a thumbs up 👍Best regardsDenisBlog: WhatTheFact.biFollow me: twitter.com/DenSelimovic
- selimovd
Most Valuable Professional
Hey salexa ,
If you need any help please let me know.If I answered your question I would be happy if you could mark my post as a solution ✔️ and give it a thumbs up 👍Best regardsDenisBlog: WhatTheFact.biFollow me: twitter.com/DenSelimovic- salexa
Helper II
thanks for the help, with your formula I have the desired results 😉
