Anonymous's avatar
4 years ago
Calculate changeover between products chronologically - difference between rows
Hallo all,
  i cannot find the way to do the following logic which is difference between rows, here is an example:
- the next Start date if a product in a certain machine is the same -   for example  for machine A firstdate (01.01) "apples", nextdate 16.02 "Apples" therefore  here  there is "no changeover"
- the next  condition if product in next date is different than "changeover" for example,  for Machine B, date: 20.08.  "carrots" and Machine B, date: 05.10. "chocholates" therefore there was a "changever.
is there a way to calculate the difference between rows chronologically when we have several machines ?
thank you all alot for the help !
Miguel
OrderStart date Machine ProductChangeover ( to be calculated)
12345601.01.16Machine AApples
23456716.02.16Machine AOrangeschangeover
34567803.04.16Machine CPearsno changeover
45678919.05.18Machine BCarrotschangeover
56790004.07.16Machine A Orangesno changeover
67901120.08.16Machine BCarrotsno changeover
79012205.10.16Machine BChocolateschangeover
90123320.11.16Machine AOrangesno changeover
12344005.01.16Machine BChocolateschangeover
11234521.02.16Machine CPears
12345608.04.16Machine CAppleschangeover
13456724.05.16Machine BCarrotsno changeover
14567809.07.16Machine AOrangesno changeover
    4 years ago
    Hi Anonymous ,
    I created a sample pbix file(see attachment) for you, please check whether that is what you want. You can create a calculated column as below:
    Changeover =
    VAR _predate =
            MAX ( 'Table'[Start date] ),
            FILTER (
                'Table',
                'Table'[Machine] = EARLIER ( 'Table'[Machine] )
                    && 'Table'[Start date] < EARLIER ( 'Table'[Start date] )
    VAR _preprod =
            MAX ( 'Table'[Product] ),
            FILTER (
                'Table',
                    && 'Table'[Start date] = _predate
        IF (
            ISBLANK ( _preprod ),
            BLANK (),
            IF ( _preprod = 'Table'[Product], "no changeover", "changeover" )
    Or you can create a measure as suggested by speedramps :
    Measure =
    VAR _seldate =
        SELECTEDVALUE ( 'Table'[Start date] )
    VAR _selmac =
        SELECTEDVALUE ( 'Table'[Machine] )
    VAR _selproduct =
        SELECTEDVALUE ( 'Table'[Product] )
    VAR _predate =
            FILTER (
                ALLSELECTED ( 'Table' ),
                'Table'[Machine] = _selmac
                    && 'Table'[Start date] < _seldate
    VAR _preprod =
            FILTER (
        IF (
            BLANK (),
            IF ( _preprod = _selproduct, "no changeover", "changeover" )
    If the above one can't help you get the desired result, please provide some sample data in your tables (exclude sensitive data) with Text format and your expected result with backend logic and special examples. It is better if you can share a simplified pbix file. You can refer the following link to upload the file to the community. Thank you.
    How to upload PBI in Community
  • Hi yukipilas
    Please consinder this solution, clcik the thumbs up and accept as solution button. Thank you
    Changeover =
    VAR mydate= SELECT(table[startdate])
    VAR myproduct = SELECT(table[product])
    VAR prevdate=
    CALCULATE(MAX(table[startdate]),
    ALLEXCEPT(table[machine]),
    table[startdate]) < mydate)
    VAR prevproduct =
    CALCULATE(SELECT(table[product],"Nonefound"),
    table[startdate]) = prevdate)
    SWITCH(TRUE(),
    prevproduct = "Nonefound", BLANK(),
    myproduct  = prevproduct, "no changeover",
    "changeover"
      i  looked for a similar " Select"  but it doesnt seem to work,
      Changeover =
      VAR mydate= ALLSELECTED(Witz_vwKonfektionierung[StartDatum])
      VAR myproduct = ALLSELECTED(Witz_vwKonfektionierung[Traegerbahnbreite])
      VAR prevdate=
      CALCULATE(MAX(Witz_vwKonfektionierung[StartDatum]),
      ALLEXCEPT(Witz_vwKonfektionierung,Witz_vwKonfektionierung[LeoMat]),
      Witz_vwKonfektionierung[StartDatum]) < mydate
      VAR prevproduct =
      CALCULATE(ALLSELECTED(Witz_vwKonfektionierung[Traegerbahnbreite]),"Nonefound",
      Witz_vwKonfektionierung[StartDatum]) = prevdate
      SWITCH(TRUE(),
      "changeover"
      • speedramps's avatar
        speedramps
        Hi again yukipilas
        I am so sorry for my typing mistake, I did it on my mobile phone instead of the using the laptop. 😀
        It should have been SELECTEDVALUE. 😀😀
        I think should work provising that you Date column is a Date type field.
        If it is a text field then the < logic may give undesired results
        Changeover =
        VAR mydate= SELECTEDVALUE(table[startdate])
        VAR myproduct = SELECTEDVALUE(table[product])
        VAR prevdate=
        VAR prevproduct =
        CALCULATE(SELECTEDVALUE(table[product],"Nonefound"),
        SWITCH(TRUE(),
        "changeover"
    Hallo,
    thank you for the answer,  there is no "Select" in either Measure or Columns what function did you mean ?
    kindest regards,
    Miguel
    Hi Anonymous ,
    Changeover =
    VAR _predate =
            FILTER (
                'Table',
    VAR _preprod =
            FILTER (
                'Table',
        IF (
            BLANK (),
    Measure =
    VAR _seldate =
    VAR _selmac =
    VAR _selproduct =
    VAR _predate =
            FILTER (
    VAR _preprod =
            FILTER (
        IF (
            BLANK (),
      Hi Rena !
      Thank you very much,
      that worked great !
      i have one small issue with the data, which is,  when the Orders repeat, i have repeated data sets were Changeover and No changeover can appear double.
      based on the Column results, can i make a measure that counts only "changeover" order"no changeover"  from distinct orders ?
      Thank you !
      Miguel
        Hi Anonymous ,
        You can create a measure as below to get it:
        Measure =
            DISTINCTCOUNT ( 'Table'[Order] ),
            'Table'[Column] IN { "changeover", "no changeover" }
