Syndicate_Admin's avatar
Icon for Administrator rankAdministrator
7 years ago
Building a flow with two flows in sequence
Hello,    I have a PowerBI Dashboard with daily alerts, as it is refreshed daily. I wanted the alerts to trigger a mail to clients, but once a week, not daily. So, I wanted to build two flows in se...
  • laura_gb's avatar
    7 years ago
    If I understand correctly you only want a Power BI alert to be active oneday a week, Monday for example if the alert is triggered you want an email to be sent but if it is any other day of the week you don't want any actions to happen?
    If that is the case you can add the logic of only acting on a particular day in the flow triggered by the Power BI alert. First calculate which day of the week it is using the expression dayOfWeek(utcNow()). In my example I used Initialize Variable to save it in a Variable called weekday.
    Then I added a condition based on weekday value, 0 = Monday so my example only sends the email if it is a Monday. Rest of the week it does nothing.
    Does that help? If so please mark this as the answer to help future Flow writers
    Regards
    Laura GB
