dguevara
Advocate IV
10 years agoBest way to develop and implement a solution
Hi Everybody... what is the best way to implement an enterprise solution working with large databases, because I can develop my model in Power BI Desktop and ok no problem, the problem is that there...
10 years agoNot applicable
dguevara For enterprise level solutions nothing beats going the Tabular model route. Rather than use the Power BI Desktop, if you develop your tabular model and deploy to an SSAS instance there are no limitations on size, and Power BI can direct query your SSAS instance using the Analysis Services Connector or Enterprise Gateway (which will replace the AS Connector eventually).
AliSharifi
10 years agoAnonymous, How about SSAS multi dimensional model, I guess it has been supported in the new Desktop realeae.
