Best way to develop and implement a solution
dguevara For enterprise level solutions nothing beats going the Tabular model route. Rather than use the Power BI Desktop, if you develop your tabular model and deploy to an SSAS instance there are no limitations on size, and Power BI can direct query your SSAS instance using the Analysis Services Connector or Enterprise Gateway (which will replace the AS Connector eventually).
- AliSharifi10 years ago
Anonymous, How about SSAS multi dimensional model, I guess it has been supported in the new Desktop realeae.
- Anonymous10 years agoNot applicable
AliSharifi Absolutely a viable option. I assumed based on the question that SSAS in general wasn't considered initially. Given that assumption, I recommended Tabular over Multi-dimensional as the learning curve is much lower initially, while the gains are immense. There are scenerio's for each solution in which one may be better than the other.
