ejethan123's avatar
ejethan123
1 year ago
Beginner, need help finding a solution to filter based on another date column.
Hi all, bit of a newbie here doing his best after our main data guy just left and am here to pick up the peices.    I have a list in power BI Desktop and have been requested to filter a column that...
  • Greg_Deckler's avatar
    Greg_Deckler
    1 year ago
    ejethan123 Did you create it as a column or a measure? It needs to be a measure and you need to use it in a visual where the measure has the context for each associated date. If you want a column you would do this:
    Selector Column =
      VAR __Date = [Submitted Date]
      VAR __Status = [Status]
      VAR __Result = IF( __Status = "Closed" && __Date < TODAY() - 30, 0, 1 )
      __Result
