RD6308's avatar
RD6308
4 years ago
Beginner help with finding the difference between two tables
I have two tables:   An annual budget, organized by month and category. Month Category Amount January Hardware Operating Expenses $5,000 February Hardware Operating Expenses $5,00...
    4 years ago
    Hi RD6308 ,
    Since you did not give a specific table, I had to create my own table for testing according to your description, please point out if there are any problems.
    Please try below steps:
    1.below is my test table
    Budget: "Index" column are used to sort the "Month" column by this column
    Transcations:
    Model:
    2. create a measure and add it to table visual
    Budget VS Actuals =
    VAR cur_month =
        SELECTEDVALUE ( Budget[Month] )
    VAR cur_budget =
        CALCULATE ( MAX ( Budget[Amount] ), Budget[Month] = cur_month )
    VAR cur_actuals =
        CALCULATE ( MAX ( Transcations[Amount] ), Transcations[Date] = cur_month )
    VAR diff = cur_actuals - cur_budget
        IF ( diff > 0, "+" & diff, "-" & diff )
    Please refer attached  .pbix file
    Best regards,
    Community Support Team_ Binbin Yu
