basic question on power bi data storage
- Anonymous5 years ago
Hi Anonymous ,
Based on my own research, your connection mode is import mode. When you make a report in Power BI Desktop, your data is imported into the local pbix, that is, the data is stored in the local pbix. When you upload to Power BI Service, data that is uploaded from users is typically sent to Azure Blob Storage.
Hope you can understand.
Stephen Tao
Hi Anonymous ,
You can refer to this article, which talked about the composition of pbix. The reason why pbix becomes larger may be due to the increase in metadata.
What is your connection mode? There are three connection modes: import, direct query and live connection. In import mode, all data is imported into Power BI Desktop, so pbix will contain data. In the case of DQ/LC, the query is sent to the data source to obtain the data, so the data will not be saved to pbix. For more information, refer to this article.
Stephen Tao
- Anonymous5 years agoNot applicable
As I said earlier my database here is Azure Tabular storage and when connecting to Azure Tabular storage from Power Bi, it does not give you option to select Import or DQ/LC, it simply asks for connection details of my table and once you provide the connection details, the tables are showed up.
As it is a cloud database , I believe it is a live connection which is being made in the backend, however I am not sure and I am looking for confirmation. Also as per article link shared above, i converted my pbix to zip and I see that my Data Model file in the zip folder has maximum size(among all files in zip folder) and it increases when my data in the database(Azure tabular storage) increases, so thats tell me data is getting imported to my pbix. Now back to original question where data is actually getting stored.
I hope you understood my doubt and now in a position to provide better clarification. Thanks- Anonymous5 years agoNot applicable
Hi Anonymous ,
Stephen Tao
