basic question on power bi data storage
- Anonymous5 years ago
Hi Anonymous ,
Based on my own research, your connection mode is import mode. When you make a report in Power BI Desktop, your data is imported into the local pbix, that is, the data is stored in the local pbix. When you upload to Power BI Service, data that is uploaded from users is typically sent to Azure Blob Storage.
Hope you can understand.
Stephen Tao
Hi Anonymous ,
It is stored in Azure Blob Storage.
Power BI uses two primary repositories for storing and managing data: data that is uploaded from users is typically sent to Azure Blob Storage, and all metadata as well as artifacts for the system itself are stored in Azure SQL Database.
For more details, please kindly refer to: Data Storage Security
Stephen Tao
- Anonymous5 years agoNot applicable
so my question is as i increase my Tabular storage data then why my pbix file size increases? i have not stored the data to my client right?? i have just made the connection to Azure tabular storage
