Azure Machine Learning - Python Query Script with Power BI dataset
- Anonymous6 years ago
This post started with how to code Python to consume Azure ML predictive model. I ended up with scripting in "R", as i found good examples.
1: Have a Azure ML predictive model
2: Want to use Power BI to consume and get the prediction from azure ML (web service)3: Add the prediction to the original dataset in Power BI.
1. Added datasource in Power BI.
2. Edit Queries
3. Transform, and choose "Run R- script"
Added this code (dataset is Power BI data, you get it directly):
# 'dataset' holds the input data for this script library("RCurl") library("rjson") library("bitops") # Accept SSL certificates issued by public Certificate Authorities options(RCurlOptions = list(cainfo = system.file("CurlSSL", "cacert.pem", package = "RCurl"))) dataset <- dataset[complete.cases(dataset), ] ##remove NaN h = basicTextGatherer() hdr = basicHeaderGatherer() req = list( Inputs = list( input1 = setNames(lapply(split(dataset, seq(nrow(dataset))), FUN = as.list), NULL) ), GlobalParameters = setNames(fromJSON('{}'), character(0)) ) body = enc2utf8(toJSON(req)) api_key = "<replace key>" # Replace this with the API key for the web service authz_hdr = paste('Bearer', api_key, sep=' ') h$reset() curlPerform(url = "<replace url>", # Replace this with the URL for the web service httpheader=c('Content-Type' = "application/json", 'Authorization' = authz_hdr), postfields=body, writefunction = h$update, headerfunction = hdr$update, verbose = TRUE ) headers = hdr$value() httpStatus = headers["status"] if (httpStatus >= 400){ result.error <- data.frame("Error") }else{ result.json = h$value() result.list = fromJSON(result.json)$Results$output1 result.list.final <- lapply(result.list, FUN = function(x) lapply(x, FUN = function(y) if( is.null(y) ){y <- NA}else{y <- y})) result.df <- data.frame(do.call(rbind.data.frame, result.list.final)) result.df = merge(dataset,result.df,by.x="row_id",by.y="row_id") #to combine original dataset with prediction }Found most of this code in this website:In this way, it is possible to consume Azure ML without Premium license.
Hi Anonymous,
has your question been answered?
Did you solve your problem?
If I answered your question, please mark my post as solution, this will also help others.
Please give Kudos for support.
2. Edit Queries
library("RCurl")
library("rjson")
library("bitops")
req = list(
Inputs = list(
h$reset()
postfields=body,
verbose = TRUE
}else{
