Azure Machine Learning - Python Query Script with Power BI dataset
- Anonymous6 years ago
This post started with how to code Python to consume Azure ML predictive model. I ended up with scripting in "R", as i found good examples.
1: Have a Azure ML predictive model
2: Want to use Power BI to consume and get the prediction from azure ML (web service)3: Add the prediction to the original dataset in Power BI.
1. Added datasource in Power BI.
2. Edit Queries
3. Transform, and choose "Run R- script"
Added this code (dataset is Power BI data, you get it directly):
# 'dataset' holds the input data for this script library("RCurl") library("rjson") library("bitops") # Accept SSL certificates issued by public Certificate Authorities options(RCurlOptions = list(cainfo = system.file("CurlSSL", "cacert.pem", package = "RCurl"))) dataset <- dataset[complete.cases(dataset), ] ##remove NaN h = basicTextGatherer() hdr = basicHeaderGatherer() req = list( Inputs = list( input1 = setNames(lapply(split(dataset, seq(nrow(dataset))), FUN = as.list), NULL) ), GlobalParameters = setNames(fromJSON('{}'), character(0)) ) body = enc2utf8(toJSON(req)) api_key = "<replace key>" # Replace this with the API key for the web service authz_hdr = paste('Bearer', api_key, sep=' ') h$reset() curlPerform(url = "<replace url>", # Replace this with the URL for the web service httpheader=c('Content-Type' = "application/json", 'Authorization' = authz_hdr), postfields=body, writefunction = h$update, headerfunction = hdr$update, verbose = TRUE ) headers = hdr$value() httpStatus = headers["status"] if (httpStatus >= 400){ result.error <- data.frame("Error") }else{ result.json = h$value() result.list = fromJSON(result.json)$Results$output1 result.list.final <- lapply(result.list, FUN = function(x) lapply(x, FUN = function(y) if( is.null(y) ){y <- NA}else{y <- y})) result.df <- data.frame(do.call(rbind.data.frame, result.list.final)) result.df = merge(dataset,result.df,by.x="row_id",by.y="row_id") #to combine original dataset with prediction }Found most of this code in this website:In this way, it is possible to consume Azure ML without Premium license.
Hi Anonymous ,
maybe that's an easier solution.
https://docs.microsoft.com/en-us/power-bi/desktop-ai-insights#using-azure-ml
If I answered your question, please mark my post as solution, this will also help others.
Please give Kudos for support.
Hi, and thanks for answering my question. Yes I have tried your solution, and it did not work. Don't know if it is a license issue or problem with my Azure ML (Tried both Azure Classic and new Azure ML Preview). It is similar to this solution: https://docs.microsoft.com/en-us/power-bi/service-machine-learning-integration and this method requires Premium license, i've got Power BI Pro license. Was able to connect Excel to the classic model, so the ML model should work. Also found this method, and have hopes that this could work with Pro license: https://powerbi.microsoft.com/de-de/blog/power-bi-azure-ml/ This is a R script, but guess it could work without writing to SQL also, just use the dataset.
- mwegener6 years agoMost Valuable Professional
Hi Anonymous,
the Azure ML integration should not require premium.
Look at this video 8:30
https://www.youtube.com/watch?v=FsK8OYagidY
Hi. Thanks again.
I see the comments on the video, alot of them says you need Premium. Is that not correct?
Hi Anonymous ,
if I understand Sarina Stevens (Program Manager) correctly, Power BI Premium is needed only for the Cognitive services functions (Text Analytics & Vision).
But not for your custom model from Azure ML.
https://powerbi.microsoft.com/de-de/blog/easy-access-to-ai-in-power-bi-preview/
