Anonymous's avatar
7 years ago
avoid double count, power query equivalent for excel solution?
Hello,   I'm trying to find an equivalent or alternative solution for below excel example. Column B containts the (original) quantities, column C the calculated ones, where the value is set to 0 (z...
  • v-juanli-msft's avatar
    7 years ago
    Hi Anonymous
    In Power BI, before any transformation,
    firstly you could go to Home->Edit queries,
    Add column->add an index column from 1,
    Then close&&apply and return to Report view,
    Create measures
    Measure = CALCULATE(MIN(Table1[Index]),ALLEXCEPT(Table1,Table1[id]))
    Measure 2 = IF(MAX(Table1[Index])=[Measure],SUM(Table1[q]),BLANK())
    Maggie
