thebigwhite
Helper II
4 years agoAggregation Problem with Power BI
Hello I have the following issue: I have two tables. One with Quantity and another with values Basically the user needs a dynamic result: The want to have the minimum quantity for ...
- Anonymous4 years ago
Hi thebigwhite ,
Check the formulas:
itemview = MINX(TableA,TableA[Qty])*CALCULATE(SUM(TableB[amount]),FILTER(TableB,TableB[Value]=SELECTEDVALUE(TableA[Item]))) groupview = CALCULATE(MIN(TableA[Qty]),ALLEXCEPT(TableA,TableA[Item],TableA[Group]))*CALCULATE(SUM(TableB[amount]),FILTER(TableB,TableB[Value]=SELECTEDVALUE(TableA[Item])))Best Regards,
Jay
mangaus1111
Solution Sage
4 years agois the relationship 1 to many?
mangaus1111
Solution Sage
4 years agoThe same formula works for the Group View as well
