thebigwhite's avatar
thebigwhite
4 years ago
Aggregation Problem with Power BI
Hello I have the following issue:    I have two tables.  One with Quantity and another with values   Basically the user needs a dynamic result:  The want to have the minimum quantity for ...
    4 years ago
    Hi thebigwhite ,
    Check the formulas:
    itemview = MINX(TableA,TableA[Qty])*CALCULATE(SUM(TableB[amount]),FILTER(TableB,TableB[Value]=SELECTEDVALUE(TableA[Item])))
    groupview = CALCULATE(MIN(TableA[Qty]),ALLEXCEPT(TableA,TableA[Item],TableA[Group]))*CALCULATE(SUM(TableB[amount]),FILTER(TableB,TableB[Value]=SELECTEDVALUE(TableA[Item])))
    Jay
