Aggregation Problem regarding finding average for repeated values
Im facing an issue regarding aggregation and Im doing average of a value. I have below values and Im trying to find the average value but Im not able to get the values correctly. Any help will be greatly appreciated. Here I need to define a measure that will calculate average length of stay ofcourse I need to have this measure at all granular levels. But when i take the sum goes wrong or Im not able to calculate at each level as well. Here the same values repeat for every business date. We need to pick only one Length of Stay for a reservation and then find out the average . Im looking for a solution that will work for individual level as well as when aggregated as well ie in the below scenario at a daily level and also at the hotel level in total.
Anonymous ,
Create measures using dax below:
Average Length of Stay for Hotel = AVERAGEX ( SUMMARIZE ( 'Table', 'Table'[Reservation], "Length", CALCULATE ( MAX ( 'Table'[Length of Stay] ), ALLEXCEPT ( 'Table', 'Table'[Reservation] ) ) ), [Length] ) Average Length of Stay May be for Busniness Dates 04-Jan to 05-Jan = AVERAGEX ( SUMMARIZE ( FILTER ( 'Table', 'Table'[Business Date] IN { DATEVALUE ( "04-jan-20" ), DATEVALUE ( "05-jan-20" ) } ), 'Table'[Reservation], "Length", CALCULATE ( MAX ( 'Table'[Length of Stay] ), ALLEXCEPT ( 'Table', 'Table'[Reservation] ) ) ), [Length] )Community Support Team _ Jimmy Tao
- v-yuta-msftCommunity Support
Anonymous ,
- AnonymousNot applicable
Thanks a lot for your reply. Can we have a single measure or rather a generic measure that will work across all or both the scenarios that it will work for any granularity .
Here in the below example we are seeing a filter hardcoded as 04 and 5th Jan as well.- amitchandakSuper User
You have to try something like this. But before that, you have to make sure you unique reservation
CALCULATE(countx(SUMMARIZE(filter(CROSSJOIN(Table2,Dim_Date),Dim_Date[Calendar_Date] >= Table2[StayStartDate] && Dim_Date[Calendar_Date]<= Table2[StayEndDate]),Dim_Date[Calendar_Date]),Dim_Date[Calendar_Date]),CROSSFILTER(Dim_Date[Calendar_Date],Table2[StartDate],None))In summarize , you can add reservation id as one group by along with date
