Adding a simple index column using dax
- 3 years ago
So if I understand you correctly, the rows marked "Must Move" should be ranked as more important (i.e. lower index) than "Flexible", with "Not Move" being less important.
If you have this Column already:
Foo = "Foo"And this column:MyPriority = IF ( [Move priority] = "Must Move", 1, IF ( [Move priority] = "Flexible", 2, 3))Then you can add this column:My Rank = RANK(DENSE,,ORDERBY('Table'[MyPriority], ASC, 'Table'[MATNR], ASC),DEFAULT,PARTITIONBY('Table'[Foo]),)Result:
Also my visual would be a table showing relevant columns. The end goal is to partition this material list & assign each to specific dates. So materials with cumulative sum(CS)<500 would be assigned to a specific order date, materials with 500<CS<=1000 to another date... & so on
This solution worked wonderfully. I was able to assign unqiue serial numbers to all the rows. Thanks a lot!
Can I also trouble you with a follow-up questions. Now, when I try to calculate the cumulative sum using the formula below, it gives me the sum of all pieces (16) in all rowsPieces_cumulative = CALCULATE(SUM('TABLE'[pieces]), FILTER( ALL('table'),'TABLE'[Serial Number]<=MAX('TABLE'[Serial Number])))
Could you please point out what am I doing wrong here?
Thanks in advance!- ToddChitt3 years ago
If the solution worked, accepting it as such lets other know where to find answers. Plus it really makes me feel good and I like to feel good. 🙂
For your cumulative sum issue, try this post:
Solved: Cumulative sum in DAX - Microsoft Fabric Community
Your DAX looks right, Can you build a simple table visual with the following columns: [Serial Number], [pieces] ,[cumulative DAX measure].
Sorry for that. I have accepted the solution!
Also, I notice that the cumulative sum formula I proposed, works if I use it as a measure instead of a calculated column. However, I would like to have the sums in a calculated column as I have to use it for further analysis. Additionally using measure for cumulative sum makes my report slower as the measure has to be evaluated for 60,000+ rows for every change I make in the tabular visual.
Kindly help me to create a cumulative sum calculated column?
