Add same column rows with same column next row
Hi All
I have one column called ColumnA andI want some like below in Total column in powerbi.
Note: I dont have any other column in data model.
| ColumnA | Total |
| 0.15% | |
| 0.14% | 0.29% |
| 0.10% | 0.24% |
| 0.09% | 0.19% |
| 0.09% | 0.18% |
| 0.09% | 0.17% |
| 0.08% | 0.17% |
- Anonymous3 years ago
Hi Sandeep13 ,
It is working for me. Please see below screenshot :Try to adding the Index column in Power Query editor using this
Please sort your table before adding the Index column.
- AnonymousNot applicable
Hi Sandeep13 ,
You need to create an Index column in your table first and then add a calculated column with following DAX formula:Total (column) =
var previndex = CALCULATE(MAX(Sheet1[S.no]) - 1)
var prevvalue = CALCULATE (SUM (Sheet1[ColumnA]),FILTER (Sheet1,Sheet1[S.no] = EARLIER (Sheet1[S.no]) - 1))
Return IF(previndex > 0, CALCULATE(SUM(Sheet1[ColumnA]) + prevvalue), BLANK())Format the above column as percentage.
This will give you the desired result(below screenshot):
Give a Thumbs Up if this post helped you in any way and Mark This Post as Solution if it solved your query !!!
- Sandeep13
Helper III
Hey
Thank you for your response. But I am getting data like this when i apply your logic in my data.
Total (column) =var previndex = CALCULATE(MAX(Sheet1[Index]) - 1)var prevvalue = CALCULATE (SUM (Sheet1[Sales_Percentage]),FILTER (Sheet1,Sheet1[Sales_Percentage] = EARLIER (Sheet1[Index]) - 1))ReturnIF(previndex > 0, CALCULATE(SUM(Sheet1[Sales_Percentage]) + prevvalue), BLANK())Note: I created index columnkIndly check
Hey Sandeep13
Can you please try to change the column name from "Index" to something else?
Since it is a Power BI keyword it might affect the calculation. I faced this same issue in the begining when i was solving your problem statement.
- Sandeep13
Helper III
Hey Thank You its working in my dummy data but when i am implementing in my actual data its give me wrong output.
I have 1M Plus data
Total (column) =var previndex = CALCULATE(MAX(Master[Num_Rnk]) - 1)var prevvalue = CALCULATE (SUM (Master[Manual_Group_Volume]),FILTER (Master,Master[Num_Rnk]= EARLIER (Master[Num_Rnk]) - 1))ReturnIF(previndex > 0, CALCULATE(SUM(Master[Manual_Group_Volume]) + prevvalue), BLANK())- AnonymousNot applicable
Can you share a sample of your data with me? You can modify your data if needed and just share a file with 100 rows or so.
- Sandeep13
Helper III
I am sharing few records for your reference. I am not adding index_coloum
Manual_Group_Volume is % of Total_Count (sum(Total_Count)/Total_Count) just for your referenece.
CLIENT_SUPPLIER CHANNEL INSERT_DT HIT_IND TOTAL_COUNT PROD_TYPE Sector.Category Product.Bureau Year Manual_Group_Volume PC Financial Services Pvt. Ltd. CPU_2 Thursday, September 30, 2021 MATCH 448270 CIR NBFC Consumer 2021 0.15% PC Financial Services Pvt. Ltd. CPU_2 Friday, October 29, 2021 MATCH 416276 CIR NBFC Consumer 2021 0.14% PC Financial Services Pvt. Ltd. CPU_2 Thursday, July 29, 2021 MATCH 299861 CIR NBFC Consumer 2021 0.10% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, May 9, 2023 MATCH 279887 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.09% CapFloat Financial Services Pvt Ltd CPU_2 Sunday, August 14, 2022 MATCH 263166 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.09% CapFloat Financial Services Pvt Ltd CPU_2 Saturday, August 6, 2022 MATCH 262598 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.09% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, July 6, 2022 MATCH 248081 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.08% PC Financial Services Pvt. Ltd. CPU_2 Friday, July 30, 2021 MATCH 240220 CIR NBFC Consumer 2021 0.08% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, April 26, 2023 MATCH 232250 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.08% CapFloat Financial Services Pvt Ltd CPU_2 Saturday, January 8, 2022 MATCH 225790 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.08% PC Financial Services Pvt. Ltd. CPU_2 Tuesday, June 29, 2021 MATCH 217030 CIR NBFC Consumer 2021 0.07% PC Financial Services Pvt. Ltd. CPU_2 Monday, August 30, 2021 MATCH 215231 CIR NBFC Consumer 2021 0.07% CapFloat Financial Services Pvt Ltd CPU_2 Saturday, January 28, 2023 MATCH 210542 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.07% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, November 29, 2022 MATCH 202276 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.07% CapFloat Financial Services Pvt Ltd CPU_2 Saturday, October 22, 2022 MATCH 178189 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.06% CapFloat Financial Services Pvt Ltd CPU_2 Thursday, April 21, 2022 MATCH 176502 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.06% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, May 31, 2023 MATCH 171882 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.06% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, May 10, 2023 MATCH 168478 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.06% CapFloat Financial Services Pvt Ltd CPU_2 Saturday, February 18, 2023 MATCH 161517 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Thursday, December 22, 2022 MATCH 161247 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, March 28, 2023 MATCH 159866 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Sunday, January 29, 2023 MATCH 153123 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, March 2, 2022 MATCH 151364 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Friday, October 21, 2022 MATCH 149444 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, December 28, 2021 MATCH 137470 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2021 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Monday, November 28, 2022 MATCH 136228 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.05% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, March 7, 2023 MATCH 134849 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.04% CapFloat Financial Services Pvt Ltd CPU_2 Tuesday, February 1, 2022 MATCH 134193 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.04% Acko General Insurance CPU_2 Thursday, July 1, 2021 MATCH 132235 CCM_SMARTMATCH_ACKO Insurance Consumer 2021 0.04% PC Financial Services Pvt. Ltd. CPU_2 Tuesday, August 31, 2021 MATCH 128269 CIR NBFC Consumer 2021 0.04% CapFloat Financial Services Pvt Ltd CPU_2 Wednesday, April 20, 2022 MATCH 128226 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2022 0.04% CapFloat Financial Services Pvt Ltd CPU_2 Friday, May 26, 2023 MATCH 127819 ONLINE ACCOUNT REVIEW Fintech NBFC Consumer 2023 0.04%
