_google's avatar
_google
8 years ago
#1 HELP_DAX RANKX Function Strange issue
Hi
I need some help for issue with RANKX function with DAX. (I tried learn it from net, but when i populate in my data table, it does not work.
- My data source : I have only one source table in the model.
- I need Rank of Product in one column and Rank of Product with Material in another column.
Function are
Rank Total Profit by Product SUM:=RANKX(ALL(fUnits[Product]),CALCULATE(SUM(fUnits[Profit])))
Rank Total Profit by Product within Manuf:=IF(HASONEVALUE(fUnits[Product]),RANKX(ALLEXCEPT(fUnits,fUnits[Product]),CALCULATE(SUM(fUnits[Profit]))))
Report view
ManufacturerProductTotal ProfitRank Total Profit by Product SUM#Rank Total Profit by Product within Manuf
Bower Booms3 MTA$142,960.1811
Bower BoomsAussie Quad$131,252.8321
Channel CraftKangaroo$135,467.6911
Channel CraftOmega$125,677.4021
Channel CraftV Rang$82,626.5331
Colorado BoomerangsAspen$288,120.8111
Colorado BoomerangsCrested Beaut$225,621.6421
Colorado BoomerangsYanaki$164,658.4131
Gel BoomerangsBellen$273,704.0721
Gel BoomerangsQuad$495,972.3811
Gel BoomerangsSunshine$194,931.7731
Manu RangsManu Distance$208,751.2111
Manu RangsManu MTA$203,058.3521
Turning PointDarnell Fast Catch$361,857.4511
Turning PointDarnell V$187,139.2721
Turning PointTry Fly$82,962.2031
Grand Total $3,304,762.191
Data Table Source : This is only sample hence total any different from report view
DateProductUnitsProfitManufacturer
01/09/2017Sunshine29235.52Gel Boomerangs
28/02/2017Yanaki758.68Colorado Boomerangs
27/10/2017Darnell Fast Catch232.19Turning Point
27/09/2017Try Fly316.32Turning Point
21/07/2017Aussie Quad6128.45Bower Booms
06/08/2017Yanaki325.15Colorado Boomerangs
08/04/2017Bellen218.46Gel Boomerangs
27/05/2017Yanaki216.77Colorado Boomerangs
17/09/2017Quad12290.07Gel Boomerangs
28/11/2017V Rang27104.77Channel Craft
05/02/2017Manu Distance172.91Manu Rangs
23/08/2017Crested Beaut34361.11Colorado Boomerangs
03/07/2017Darnell V313.26Turning Point
10/08/2017Sunshine216.24Gel Boomerangs
11/06/2017Try Fly316.32Turning Point
05/07/2017Aussie Quad364.22Bower Booms
06/09/2017Darnell V43190.12Turning Point
04/01/2017Bellen327.69Gel Boomerangs
18/05/2017Sunshine756.85Gel Boomerangs
  • HI _google
    Try adding these two calculated columns to your table
    Rank of Product =
        CALCULATE(
            COUNTROWS('fUnits') ,
            FILTER(
                ALL(fUnits) ,
                'fUnits'[Profit] > EARLIER('fUnits'[Profit])
            ) +1
    Rank of Product by Manufacturer =
        CALCULATE(
            FILTER(
                ALL(fUnits) ,
                'fUnits'[Manufacturer] = EARLIER('fUnits'[Manufacturer]) &&
            ) +1
  • Hi,
    You may download my solution from here.  This has been done in MS Excel using the PowerPivot but can also be done in PowerBI desktop.  You may also import all the data and the formulas from this Excel file directly into PowerBI desktop by going to File > Import in PowerBI desktop.
    Hope this helps.
  • _google's avatar
    _google
    8 years ago
    Hi Phil
    Thanks for the solution, it work with calculated column, I was trying to do it through a measure however it helps on learning curve with DAX
    regards
  • Phil_Seamark's avatar
    Phil_Seamark
    HI _google
    Rank of Product =
        CALCULATE(
            FILTER(
                ALL(fUnits) ,
            ) +1
        CALCULATE(
            FILTER(
                ALL(fUnits) ,
            ) +1
    • Zubair_Muhammad's avatar
      Zubair_Muhammad
      HI _google
      Try this MEASURE for ranking Total Profit
      Rank Total Profit by Product SUM =
      RANKX (
          SUMMARIZE ( ALLSELECTED ( fUnits ), fUnits[Manufacturer], fUnits[Product] ),
          CALCULATE ( SUM ( fUnits[Profit] ) ),
          DESC,
          DENSE
        Zubair_Muhammad
        _google
        And this MEASURE for ranking Total Profit by Product within each Manufacturer
        Rank Total Profit by Product within Manuf =
        RANKX (
            SUMMARIZE (
                FILTER (
                    fUnits[Manufacturer] = SELECTEDVALUE ( fUnits[Manufacturer] )
                fUnits[Product]
            DESC,
            DENSE
    • _google's avatar
      _google
      Hi Phil
      Thanks for reply,
      it is giving error message
      Semantic Error :  EARLIER/EARLIEST reference to earlier row context which does not exist.
      regards
      _google
      • _google's avatar
        _google
        Hi
         Function are  Rank Total Profit by Product SUM:=RANKX(ALL(fUnits[Product]),CALCULATE(SUM(fUnits[Profit]))) Rank Total Profit by Product within Manuf:=IF(HASONEVALUE(fUnits[Product]),RANKX(ALLEXCEPT(fUnits,fUnits[Product]),CALCULATE(SUM(fUnits[Profit]))))
        Report view
  • Hi,
    Hope this helps.
    • _google's avatar
      _google
      Hi Ashish,
      Thanks for the solution, it works great. As am new to DAX, may i check logical view on using nested RANKX.
      regards
