Trouble with Request Body in Copy Data data flow
- Anonymous2 years ago
Hi DevinL ,
It seems that only when you can't use the above request code in Fabric, you also mentioned that the error is not displayed but the value of no request is displayed, but the request can be completed in Postman or Web activity, which may be caused by incompatibility with Fabric and not being recognized.
So I think you can use a web activity instead of a copy data activity might produce the right results. The output of the web activity can then be used as input for further processing.
Another point is to make sure that the API endpoints and parameters in Postman and Microsoft Fabric are exactly the same. You can also read this document: How to copy data using copy activity - Microsoft Fabric | Microsoft Learn
Yilong Zhou
Hi DevinL ,
Have you solved your problem? If so, can you share your solution here and mark the correct answer as a standard answer to help other members find it faster? Thank you very much for your kind cooperation!
Yilong Zhou
