SergioTorrinha's avatar
SergioTorrinha
Icon for Resolver II rankResolver II
2 years ago
Teams Activity stuck on 'Loading Body' - What am I doing wrong?
Hi all!
I was trying to create a teams activity, inside of one of our pipelines.
With that in mind, I am following the steps in microsoft docs about creating Teams activity here, but the thing is getting stuck right after I define the 'Post In' step.
It keeps indefinetly loading and does not move forward, as you can see in image below:
Worth noting that:
  • the account I am using to access MS Fabric is in a different domain/tenant then the account I am using to send message into Teams channel;
  • also the Teams channel is in a different tennat/domain, then the MS Fabric tenant/domain).
Am I doing something wrong?
Is there any limitation in what I stated above regarding the different accounts that I am using for both platforms?
Thanks, in advance, for the help.
  • Hi Anonymous !
    Thanks for letting me know.
    I would like to add that, today, I can no longer replicate this issue on my end. Earlier this morning, I started working (again) on my pipelines when I noticed the issue I reported above is no longer taking place.
    I apretiate, however, that you check in internally, and confirm that this issue is officially resolved.
  • I'm having the same issue and the behavior is the same from my home tenant and account. I am also unable to edit existing Teams activities.
    I can say that as of a month ago, this issue did not exist and using a tenant/account/channel that is different from the Fabric tenant worked fine.
  • Hi Anonymous !
      Hi SergioTorrinha
      The internal team has confirmed that this is an intermittent issue. So if you try again after sometime, the issue will be resolved.
      Thanks.
      • SergioTorrinha's avatar
        SergioTorrinha
        Hi Anonymous !
        Thanks for the update.
        In fact the issue seems to be resolved on my end, however with your answer I'm not confident it is really resolved for everyone.
        There are now more questions to answer:
        Is this something to do with the preview state of the 'Teams Activity'?
        Will it be solved when the feature becomes generaly available?
        Will the dev team keep monitoring this to ensure it's not going to happen in future?
  • Hi all!
    I am still looking for a solution for this issue.
    Is anyone able to help, please?
      Hi SergioTorrinha
      Thanks for using Fabric Community.
      At this time, we are reaching out to the internal team to get some help on this.
      We will update you once we hear back from them.
