Apps_devOps's avatar
Apps_devOps
2 years ago
Problem with SFTP connection
Test connection failed even the port value is added
  • v-cboorla-msft's avatar
    v-cboorla-msft
    Hi Apps_devOps
    Thanks for using Microsoft Fabric Community.
    I tried to replicate the scenario by taking a sample SFTP server and succesfully established the connection without any difficulty. Please find the screenshots for reference.
    Could you please recheck the connection name and try again.
    If the issue still persists, please share the screenshot of the connection settings?
    I hope this information helps. Please do let us know if you any further queries.
      v-cboorla-msft
      Hi Apps_devOps
      We haven’t heard from you on the last response and was just checking back to see if you have a resolution yet.
      In case if you have any resolution please do share that same with the community as it can be helpful to others.
      Otherwise, will respond back with the more details and we will try to help.
      Thanks.
        v-cboorla-msft
        Hi Apps_devOps
        We haven’t heard from you on the last response and was just checking back to see if you have a resolution yet. In case if you have any resolution please do share that same with the community as it can be helpful to others .
        If you have any question relating to the current thread, please do let us know and we will try out best to help you.
        In case if you have any other question on a different issue, we request you to open a new thread.
        Thanks.
