Problem with semantic model refresh after data transformation in Data Flow Gen2
- 2 years ago
Hello DALI007 ,
check out this post, maybe it'll help :
Re: How can I update the PowerBi semantic model sc... - Microsoft Fabric Community
Hi miguel ,
I have a similar problem.
I initially created a schema in a warehouse. I use this warehouse to create a report using PowerBi Desktop. From this point on, I can no longer see the schema changes I make in the warehouse. If I add a column to a dw table, I can't see it in the PowerBI model.
Is this normal?
How can I update the PowerBi semantic model schema when I make changes to the source structure?
What's more, even when I delete the table from the semantic model, and add it again, I get back exactly the same structure as before, without the new column...
I'd recommend posting your full scenario in the Power BI forum:
Power BI forums - Microsoft Fabric Community
It doesn't seem to be related to a Dataflow Gen2, so it might be best for someone from the Data Warehouse team or the Power BI to take a look at it
Hi DALI007
We haven’t heard from you on the last response and was just checking back to see if your query has been resolved. Otherwise, will respond back with the more details and we will try to help.
Thanks - DALI0072 years ago
Helper II
Hello Anonymous,
Not yet, actually my problem as it is indicated in the tittre of subject how to do a refresh of semantic model after an update of dataflow Gen2. To my knowledge, with the default settings, a Direct Lake dataset is automatically refreshed when the data is loaded into a Lakehouse. But in my case I have the dataflowGen2 which is updated every day (it is a parametrage that I set up) but the dataset (semantic model) is not updated.
Thank you in advance for your help.
Thanks - amolt2 years ago
Resolver I
Hello DALI007 ,
