Problem with semantic model refresh after data transformation in Data Flow Gen2
- 2 years ago
Hello DALI007 ,
check out this post, maybe it'll help :
Re: How can I update the PowerBi semantic model sc... - Microsoft Fabric Community
Is the issue that the new column is reflected in the Lakehouse but not in the automatic semantic model? Or that the new column is not reflected in the Lakehouse at all?
Yes, the new column is not reflected in the Lakehouse at all
- miguel2 years ago
Community Admin
A Dataflow Gen2 doesn't change the schema of a table in the destination at the moment.
You can either create a new table by going through the "data destination" configuration for your query and defining a new table, or make the changes in your backend (your LakeHouse) to alter the schema of a table and then update your dataflow gen2 to load the data to the updated schema. In both scenarios you'll have to go into the dataflow gen2 and update the configuration for the data destination.
hope this helps!
- amolt2 years ago
Resolver I
Hi miguel ,
I have a similar problem.
I initially created a schema in a warehouse. I use this warehouse to create a report using PowerBi Desktop. From this point on, I can no longer see the schema changes I make in the warehouse. If I add a column to a dw table, I can't see it in the PowerBI model.
Is this normal?
How can I update the PowerBi semantic model schema when I make changes to the source structure?
What's more, even when I delete the table from the semantic model, and add it again, I get back exactly the same structure as before, without the new column...- miguel2 years ago
Community Admin
I'd recommend posting your full scenario in the Power BI forum:
Power BI forums - Microsoft Fabric Community
It doesn't seem to be related to a Dataflow Gen2, so it might be best for someone from the Data Warehouse team or the Power BI to take a look at it
