Issue with Power BI Admin API 'Get Activity Events' Call using Python F-String and Token Handling
- 11 months ago
Anonymous You're running into a common issue with the Power BI Admin API's Get Activity Events endpoint. The key problem is that this API only supports querying one day at a time—not a range of multiple days.
What’s Causing the 400 Error
- The API expects:
- startDateTime and endDateTime to be on the same calendar day
- Both in UTC ISO 8601 format
- You’re passing a 2-day range, which violates the API’s constraints
How to Fix It
Update your code to loop through each day individually. Here’s a quick fix:
from datetime import datetime, timedelta import requests if "access_token" in token: access_token = token["access_token"] headers = { "Authorization": f"Bearer {access_token}" } for i in range(2): # Loop through past 2 days day = datetime.utcnow() - timedelta(days=i) start_str = day.strftime('%Y-%m-%dT00:00:00.000Z') end_str = day.strftime('%Y-%m-%dT23:59:59.000Z') url = f"https://api.powerbi.com/v1.0/myorg/admin/activityevents?startDateTime={start_str}&endDateTime={end_str}" response = requests.get(url, headers=headers) print(f"Day {i+1}: {response.status_code}") if response.status_code == 200: print("Success") else: print("Failed") print(response.text)
Pro Tips
- Make sure your app has AuditLog.Read.All permission
- Use UTC time and avoid local timezone offsets
- Consider paginating results if the volume is high
You can find more details in this Microsoft Fabric Community thread and Stack Overflow discussion.
May I ask if you have resolved this issue? If so, Can you please share the resolution steps here. This will be helpful for other community members who have similar problems to solve it faster.
If we don’t hear back, we’ll go ahead and close this thread. For any further discussions or questions, please start a new thread in the Microsoft Fabric Community Forum we’ll be happy to assist.
Thank you for being part of the Microsoft Fabric Community.
