Issue with Power BI Admin API 'Get Activity Events' Call using Python F-String and Token Handling
- 11 months ago
Anonymous You're running into a common issue with the Power BI Admin API's Get Activity Events endpoint. The key problem is that this API only supports querying one day at a time—not a range of multiple days.
What’s Causing the 400 Error
- The API expects:
- startDateTime and endDateTime to be on the same calendar day
- Both in UTC ISO 8601 format
- You’re passing a 2-day range, which violates the API’s constraints
How to Fix It
Update your code to loop through each day individually. Here’s a quick fix:
from datetime import datetime, timedelta import requests if "access_token" in token: access_token = token["access_token"] headers = { "Authorization": f"Bearer {access_token}" } for i in range(2): # Loop through past 2 days day = datetime.utcnow() - timedelta(days=i) start_str = day.strftime('%Y-%m-%dT00:00:00.000Z') end_str = day.strftime('%Y-%m-%dT23:59:59.000Z') url = f"https://api.powerbi.com/v1.0/myorg/admin/activityevents?startDateTime={start_str}&endDateTime={end_str}" response = requests.get(url, headers=headers) print(f"Day {i+1}: {response.status_code}") if response.status_code == 200: print("Success") else: print("Failed") print(response.text)
Pro Tips
- Make sure your app has AuditLog.Read.All permission
- Use UTC time and avoid local timezone offsets
- Consider paginating results if the volume is high
You can find more details in this Microsoft Fabric Community thread and Stack Overflow discussion.
Hi Anonymous,
We would like to confirm if our community members answer resolves your query or if you need further help. If you still have any questions or need more support, please feel free to let us know. We are happy to help you.
Prashanth Are
